Donstanley
- Joined
- 17 Oct 2015
- Messages
- 54
Hi
Yes I know the navigation on the PCM 2.1 is very ancient and useless compared to Waze etc, but I just like everything to work properly and I do use it occasionally.
As per title the navigation is stuck in one location and will not move from that location as if the GPS is not working. It does give directions from that location to a new selected address, but without going to the stuck location I am not sure the directions would work properly. I have never been to the stuck location.
I did remove the lead to the GPS antenna to fit a new cowl, and it does not make any difference if this lead is connected or not.
Does anyone know of any checks I can do to establish if it is a fault with the PCM or the connection to the antenna.
Regards
Don
Regards
Don
