tob_today said:Thanks for sharing the photos. Just to be clear, what are you using as the aerial? You managed to do this without sticking anything on the windscreen?
deMort said:tob_today said:Thanks for sharing the photos. Just to be clear, what are you using as the aerial? You managed to do this without sticking anything on the windscreen?
From reading this .. you unplug the amplifier then attach this unit to the existing wire from the windscreen ..
This item is whats used for fitting a PCCM .. the classic Porsche aftermarket radio ... at least it is on the 996 model as i've fitted these and recognise it .
It's a DAB splitter as i understand it .
tob_today said:Thanks rob_watti and deMort. I'm now wondering why my installer said I can only use stick-on aerials for DAB reception. My 993 is away at the moment so I can't check the windscreen, although I know it was replaced by previous owner a few years ago.
Is there an obvious way to check a windscreen for the in-built aerial? Is there a line down middle of screen or similar?
Fantastic thanks, fingers crossed mine also has the line & I'll get my installer to change it as I'm really not a fan of the stick-on aerials personally.rob_watti said:Yes a line down the middle of the windscreen. Also if you pop the clock out you can see the windscreen aerial wire behind there. I'm not sure of a way to test it is good or not to be honest.
decgraham said:Well I bought a splitter of Amazon, disconnected the live to the aerial booster and connected up the splitter for the DAB. No joy didn't work so all back to stock. :x
ATB
