JonnieD
Nurburgring
- Joined
- 25 Mar 2019
- Messages
- 490
NineExcellence said:Unfortunately you cannot compare across different models because the gearbox itself it fundamentally different.
There are too many factors involved and noise primarily is down to other factors such as diff backlash, end float measurements and how the gears are spread.
You can have two 997 Turbos for example, fit the exact same LWFW and have totally different noise results for the reasons above.
In the case of the 997.2 we rebuilt the gearbox so we were able to set all the right tolerances. You cannot assume that fitting the same identical LWFW on another 997.2 will give the same results in terms of noise, unless you are building the gearbox and setting up the diff etc.
Older Porsche models ( 993 and before ) again are more reliable in outcomes because of the design of the gearbox.
Ken
Useful insight, thanks Ken. And great job by you guys on mine :thumbs:
I can see why the gearbox differences between the models would explain why a lightweight flywheel would act in a certain way. But hadn't considered the same gearbox in different cars acting differently too.
Is it that the tolerances in the newer gearboxes vs older ones that are very different, or the gearbox design itself?
