zagamuffin
- Joined
- 26 Jun 2022
- Messages
- 37
Engine work list
Remove engine, strip, clean & prepare for re-assembly, re-assemble with all new gaskets & seals, strip & clean ancillaries, re-fit to engine, re-fit unit to car, re-commission with new fluids, a/c re-charge etc. & test.
All new high strength oversize aluminium alloy nickel silicon plated closed deck wet liners (all 6 cylinders).
New performance oversize pistons.
New crank shaft main & thrust bearing set.
New performance big end bearing set.
New timing chain set with new guide rails.
Intermediate shaft conversion (sprocket to accommodate an improved larger bearing as per the 2006 onwards revision).
Basic cylinder head overhauls (strip down, de-coke heads & valves, re-lap valves to seats, skim & re-assemble with new valve stem oil seals).
New lower temperature thermostat.
New spark plugs.
New oil/air separator.
New water pump.
3 New vent lines.
New oil cooler.
New evap valve.
New starter motor wiring harness.
New coolant tank.
4 New coolant hoses/pipes.
4 New brake pipe sections at the rear of the car.
Numerous snapped fixing repairs.
Various minor works etc.
New spark plugs.
New water pump.
3 New vent lines.
New oil cooler.
New evap valve.
New coolant tank.
