Inspired by ChrisT70's efforts at the DIY RSR, decided to have a bash at it too.
I had a set of 1.5" Hollamby modded boxes on a couple of years back which were good on the move but I tired of the rough sounding tickover and the constant nagging by SHMBO about the noise so invested a set of 2nd hand Bischoff exhausts off the bay. These were duly bagged for £99 inc delivery.
I'm no expert at metal bashing but thought 'how hard can it be?'
nipped down the local DIY shop for a few cutting discs for the grinder and got stuck into it. After about an hour had both boxes cut open. This was where the fun started.
You would have thought that you would then just pull the can off, leaving the internals behind. Noooooooo! :x
You can get about an inch clear but then need to prod and poke the internal insulation out of the can as this gets stuck when you try to pull the can. After I had all it removed, can still wouldn't budge. Finally got it free by levering the sheet steel with a large chisel and screwdriver. Can then slightly bent but figured this could be tapped back into shape after.
Next lopped off the internals (as per previous photos from Chris, but decided to leave a bit more length on the internal perforated section)
Finally for the welding. Quick call to a mate who said 'yeah, bring em over'.
Picked them up the next evening and gave them a finish off with some high temp silver paint. Hopefully this should save the mild steel inlet/outlet pipes from rusting further.
So what's the verdict? Pretty damn good I'd say.
Not as loud as I feared they would be, nice pop on the overrun nice rasp
http://www.youtube.com/watch?v=uS-Y7-URITc
(no the plates hung up on the garage wall are not off the 993)
so what about the costs:
2nd hand boxes: £99
cutting discs: £5
welding: £beer tokens only
paint: £9
this is well short of the 400 euro to Gert and even still got my original boxes to put back on. :grin:
Summary: If you are even a slight bit handy GO FOR IT, won't be disappointed
