Hello - I'm currently on the train down to Dorset to collect my first Porsche.
Found a 2007 (yes the tax is expensive) Carrera C2S:
- coupe / manual
- black on black (my favourite but subjective)
- carerra sport wheels
- chrono
- PSE
- hardback seats
- bose
- no sunroof
Its on 146,000 miles - yes its a lot...but
But its had an engine rebuild less than 5,000 miles ago and while it was out a bunch of work was done.
Engine work was:
6 x cylinder liners fitted and bored
Overhauled cylinder heads
24 valve guides
6 new genuine pistons
All new rings
New timing chains
New big end bearings
New main bearings
All new gaskets
Assembled, oil pressure tested, oil distribution tested, compression tested.
£15k was spent in total with a lot of preventative "while you in there" kind of work. I didn't spent a whole lot more than that on the car so my man maths says I've almost got the car for "a couple grand"...
As part of the deal, I've had front ARB bushes, and top mounts replaced so the front end should feel a bit tighter.
Some interior upgrades are on the cards:
- macan type steering wheel
- retrim gear lever
- repaint or trim over centre console
- feed and dye the bolster on the driver seat
Wish me luck...
- coupe / manual
- chrono
- PSE
- hardback seats
- bose
- no sunroof
Engine work was:
24 valve guides
All new rings
New timing chains
New main bearings
All new gaskets
- retrim gear lever
Wish me luck...
