Enjoyingtea64
- Joined
- 2 Nov 2020
- Messages
- 33
Hi Gents,
Just washed the car, a Boxster 987 S 2008 auto. I tried to drop the roof as I always do when its in the garage. Followed the normal procedure and when I pulled the roof opening electric switch near the handbrake, nothing happened. I locked car, opened it again, got in and still roof wouldnt open. Turned engine on and off to try and reset anything that needed resetting. Checked everything was closed including side windows, still nothing.Opened and closed roof catch a few times, nothing happened. The on last attempt everything worked as normal. Did it two more times and no problems then third time Nothing happened again!
So thats about it, I haven't fiddled with anything and its the first time its happened. Roof and all rubbers etc are spotlessly clean. The car has 50,000 on clock with careful use. Any ideas what it may be, what is a common fault here. Is there something that needs a squirt of oil or a switch or contact that is prone to wear?
Regards.
Regards.
