Becker Cascade Pro 7941 service/repair - where?
Dammit
Paul Ricard
23 Sep 2016
3,135
Hi all, I've got an issue with radio reception - it used to be great, but recently it's degraded significantly.
The amplifier and antenna have both been checked - so it's likely to be the Becker itself.
Can anyone nominate (or, better, recommend) someone/somewhere that can service a Becker Radio?
I had a becker indianapolis where the aerial wire had partially detached from the socket on the back internally. The headunit had been moved between a few cars causing this.
It was very simple fix, I removed the lid from the headunit and resoldered the connection between the board and the socket.
Yours may be a similar problem.
It took me 20 minutes.... I would look at yours if you were local, but sadly corner shop TV repair guys don't exist anymore, and if they do they charge a mint for simple repairs.
If you can't get it fixed economically I would be interested in buying it off you faulty and assume the risk of a more complex repair.
Putnoe Radio Services Ltd
Putnoe House, 12 Clifton Avenue, Hartlepool TS26 9QN
01429 869220
Official Becker Repair Agents
Old school gentleman, partially retired, does a great job. Fixed my HU couple of years back.
Thanks chaps. Is there an easy way to check if the amplifier is borked, other than buying a new one and seeing if it works again?
I would:
1) try another headunit (you or a mate must have something knocking round)
if the radio is still rubbish you know the amplifier or wiring is likely duff.
then:
2) whip the a pillar trim off and clean up the ground and connections and check the wiring and connections at every end.
if still rubbish reception then:
3) replace the amplifier
If reception is still rubbish then I dunno, trade it in for a Hyundai or something.
Done 2, car is at Precision so can't do 1, asked them to do 3 and report back (~£155). If it fixes it, winner - if not then I'll pull the unit and get it sent off to the chap mentioned up thread (thanks for that).
124,629
1,442,297
49,074
nzed23
