Hertsdriver
- Joined
- 12 Nov 2018
- Messages
- 646
Hi all,
My car (997.1 3.6) is being used daily (long drives of over an hour to and from work), and last week I had an unexpected new issue where the battery one morning was completely flat.
I thought perhaps it was just the very cold, early morning starts showing up a deficiency in the old battery that came with the car (a relatively small, lower amp Lion brand battery that was probably fine for the previous owners occasional use as a second car), so I went to Halfrauds and bought a larger Yuasa 85ah battery, fitted it and thought nothing more. However the next morning the battery was completely flat again... so I clearly have a drain somewhere.....
I don't know if its connected but I also had last week a random fault code showing on the dash saying that the rear passenger side brake light was inoperative, it would clear itself after 10 minutes or so, only to reappear the next day which si odd (have since replaced both rear brake light bulbs, although neither had blown filaments).
So anyway, with the new battery trickle charged overnight, I got the multi meter out yesterday to see if the alternator was working or not. Got a reading of 12.53 with the battery connected but nothing being used (frunk catch closed with a screwdriver as per De morts advice to stop the light from coming on) 13.29 with the engine running, and 12.98 with all accessories on (lights, hazards, fogs, heater, rear demister, radio. So I believe the alternator is doing what it should?
Shut the car off, pulled the fuse for the aftermarket radio (just in case it was this that was the issue) and the battery measured 12.04. and hour later it measured 11.88, and an hour later had dropped to 11.74. by 9pm it was down to 8.82.... :?: seems like quite a drastic drop, wonder if there are any likely culprits to check that are known to fail before I have to start the process of pulling fuses and measuring...
Thanks :thumb:
Thanks :thumb:
