Paul_S
- Joined
- 3 Mar 2018
- Messages
- 235
Hi All
What a ballache of a job, but it is typical that I make things harder than they need to be....
As posted elsewhere, I had a boost leak on the Turbo so as I was going to have to dismantle a few bits anyway I decided to take advantage of Black Friday and bought the upgraded Intercoolers and Y-Pipe from DO88. The car was laid up for some other mods so no rush to fit but last week I started the job. I found the O-Ring on the left Intercooler to Y-Pipe hose was broken so I am assuming this was the issue (I found the hose was loose when I was upgrading the engine mounts, so it makes sense that was the source).
Getting everything off is easy enough, and modifying the intercooler shrouds was OK if a bit messy, but putting it all back together is painful. I watched so many videos finding where people are re-mounting the intercoolers, I eventually worked out the technique but the first one took me over an hour. Then I had to fit the new hoses between the Intercoolers and the Y-Pipe which is where it gets even harder and I need to check some things with the gurus on here...
The hoses need to be oriented, and then the Y-Pipe mounts over them. I cannot get the right hose to line up properly, it is all clamped down but the Y-Pipe is not sitting in the mounting hole because the hose lifts it out. It looks ok but I just cannot get it to seat. Does anyone have a recommendation for the technique here? Do I pull the right intercooler away slightly to make some room, as it seems like the hose is poerhaps not oriented exactly straight? Is there is a good lubrication method to help or is it just twisting and brute force?
I don't want to remove the Y-Pipe again, the left hose in the picture above is perfectly seated. All of the hoses are clamped up and secure, so right now I think it would perform fine but it doesn't look right. DO88s instructions are useless.
Have I done anything in the wrong order? Is it Yipe and hose connections first, then fit the intercoolers? I can't see how that's any easier or better but I have the opportunity to try.
