So the owners manual states 32 litres for the coolant in a 997 C2S manual yet 996 is 22 litres....
Has anybody actually measured how much comes out or is replaced?
So far I have around 22 litres out and have drained from : -
1) rad lower hose at rads
2) thermostat removed
3) water pump removed
4) drain plug on engine block
5) heater feed & return at engine
6) blown through the system with low pressure from a compressor from filler cap & heater feed.
7) raised front and rear of car independently to tip out fluids
I'm buggered if I can fathom where the other 10 litres are. Are they actually there or is the manual optimistic - there appears to be a big difference between 996 and 997 in capacity.
The reason I am trying to get all coolant out is a change of coolant type, whilst it is compatible with the Porsche (pentosin G12) it's very old and I believe no longer preventing corrosion. (I know it is stated as lifetime coolant but that's a discussion for another time )
