After a little bit of advice if possible.
My 997.2 has inadvertently been driven for approx. 25 miles without the coolant cap fitted and as a result it has lost coolant. With the engine cold the level is about 5mm below the minimum mark. No overheating warnings were seen but the oil was hotter than normal, no idea what the water temp was showing.
Can anyone advise if it is likely the engine may have suffered as a result and is it is likely any air has got into the cooling system/pipes and lastly whether it is advisable to drive it.
The engine is the 3.8 with approx 50k miles on it.
Any help appreciated.
