Cunno
- Joined
- 13 Dec 2008
- Messages
- 2,652
johntyboy said:Hi
There seems to be a lot of noise about the standard LSD plates in 996/997 diffs being made out of chocolate and not lasting very long. This isn't strictly true. Pre load of the clutch pack is very low from factory (5 to 15 NM) and only a very small amount of wear on the clutch pack results in zero pre load on the diff. This results in effectively an open diff.
There are 3 options as recommended by Matt at Fearnsport.
1. Cup Clutch pack. (Matt did not recommend for road use this is too aggressive, this pack was designed for use with slick tyres on Cup cars and road tyres simply don't have enough grip to brake away the diff resulting in a car that pushes)
2. Gaurd Transmittions Clutch pack (A great good quality replacement clutch pack which results is far more pre load than the factory set up, around 50 NM from memory)
3. Fearsport uprated Belville Washers. (The new washers are thicker and more pronounced than the factory washers, this puts more pre load on the original clutch pack. Obviously the clutch pack still needs to be serviceable but mine at 40,000 miles were).
I chose the upgraded Belville washers from Matt and fitted them myself. Quite easy and can be completed with the gearbox in the car.
My standard "Chocolate"clutch plates. Since the upgraded Belville washers were installed the Diff has worked absolutely fine and I've completed a number of track days without issue. Car now has 47,000 miles on it.
Hope that helps.
Kind Regards
Are you talking 996 or 997 here? This thread is titled 997.1?
