I agree that handbrake switch definitely looks ok.
The control unit is on the left-hand side of the car so I'm not sure why you looking passed the steering column unless you have have a left hand drive car?
I also agree it is worth checking the switch. It is relatively easy to pull the switch block out of the console but be careful because the wires are very short so there is not much room to play with.
Also I found it much easier to see and remove the control unit if I first remove the glove box which is relatively easy to do. Again this only makes sense if you have a UK right hand drive car with the control unit on the passenger side.
