MisterCorn
- Joined
- 8 Jan 2011
- Messages
- 9,411
As per the other threads on suspension overhaul, I took the wise advise of the forum and had a go at cutting off the lower arms rather than using a slide hammer. With the lower arm disconnected from the hub it was easy to get a hacksaw in to the front edge.
I then undid the two top supports which enabled me to move the hub forward enough to get behind the driveshaft and repeat the operation on the other side of the arm. It then fell out...
I then did the only sensible thing and put the arm on the press to see how much force it took to get the bolt out:
The answer is about 1.5tons. The bolt looks fine, but as expected dry as a bone.
Toe adjustment arm next, but I have an air powered body saw arriving tomorrow to have a play with, I'll let you know how it goes.
