rigsby99 said:
Alex said:
So do you think that by fitting a pipe in the side of the oil filter that allows oil to be pumped to the other end of the shaft have zero effect on pressure at (for example) the crank bearings or cam shafts?
No it wouldn't as long as the bearing, oil cooler, gauge etc didn't leak or, in the case of a bearing was tight enough to maintain the pressure. Worn main bearings will show a drop in oil pressure assuming that the pressure control system cannot compensate.
There's pressure and there's flow. A gauge requires pressure but not flow, so it will not affect the flow of oil (or therefore the available pressure) to other components.
An oil-fed bearing, however, requires a flow of oil and incurs a pressure drop across it, so it would potentially affect the flow of oil (and available pressure
Of course you would expect the capacity of the oil pump and the pressure regulator to be such that the minor effect of an oil fed bearing would be inconsequential to the oil flow and pressure to other components, but it will depend to some extent on where the tapping is and what the flow characteristics of the oil fed bearing are. Given the M96 is known to be prone to surge in hard cornering I'm not sure I'd risk it.
