Ok so I'm in the process of replacing my catch tanks and some oil hoses - I noticed yesterday that the left hand turbo wastegate has a couple of mm movement and feels loose in the seating, the drivers side is quite tight in comparison? I'm assuming that the passenger side is not how it should be - correct? The actuator rods are in pretty good condition but the adjuster nut on the rear left is pretty much just a corroded blob of mess so I'm going to try and remove this - does any one know what size the thread is?
The drivers side has no adjuster nuts on it - only a clip that is pretty corroded too.
Once I have sorted this out I will need to set it up, the car is not mapped and is on K16 turbos - can anyone advise me on the correct procedure for this please?
Lots of questions I know sorry - thanks in advance.
