Driveshaft
26 Jan 2009
1,400
Folks,
I need to repair my driveshaft, I've removed the CV joint on the hub end which was damaged. I need a replacement unit but looking at all CV joint replacement items across the usual sites they only seem to carry the CV joints for the gearbox side.
My question is whether the same CV joint item is used at the Hub end?, or at least the innards of the CV joint?.
Trev
Stand down ya'll, went out to garage last night and disassembled the Hub end of the drive shaft, appears the innards of the CV joint do indeed fit into the cup at the Hub end.
Phew just need a couple of CV joints and boots now
Trev
Let us know how you get on Trevor, I've been avoiding the CV boot job for ages, I'd be interested in how hard/messy this job is
Ash
Kev at Coppull did mine last year he described it as a real pia.
Cookies are required to use this site. You must accept them to continue using the site. Learn more...
