The ECP part no was 219440150 and I paid £44.09. The part is EIS, they also sell the OEM Valeo part for about £70 IIRC.
My car is 996.2 which is a bit different from the 996.1 for fitting so the Pelican guide is just that, not the complete answer - I took the glove box out and then it was straightforward. Anyway, it's quite an easy job as long as you are slim/flexible enough to work under the dash!
I found out the door catch/latch for the Audi TT MK1 are the same as the 996 and Boxsters when I fixed mine last week, they are quite a bit cheaper but the same part.
For the drivers/off side I think the generic code is 8N2837016B
my 996.2 has the type from the 2nd pic.
Incidentally if you search for the vw part number then there are several versions of these on eBay & Ali-express with a built in reverse camera which should save having to cut an extra hole in your bumper.
