I have stock rims and need to change all 4 tyres. For the rear tyres I have gone for the Michelin PS2 dues to lack of MPSS in 295/30/R18.
For the front tyres I can get both MPS2 and MPSS in 225/40/R18. Have any of you guys gone with MPSS for the fronts and found them better than the MPS2? Shall I just stick with the MPS2 for the fronts as well?
Thanks for the replies guys. The only reason I was willing to try the MPSS was that I had them on my m3 and they were brilliant. The tyre had two separate sections, the outer edge had softer rubber which only came into contact when it was under load ie in a corner for better grip. I hadn't considered ps4's as I hadn't heard much about them. As some of you have said it's probably not good to mix different types so Il go with the PS2s
