Need to get another new splitter and trying to find the correct part number...there are lots of references to 'standard' and the 'cup' versions online but I think my previous one was a different version again? Are there 3 OEM versions available?
'standard' 996 505 986 92 01
The bottom lip gets shorter around the side of the car and blends into the PU just ahead of the front wheel. Expensive
'the last one I had'
Same depth as the standard but bottom lip protrudes all the way around and does not blend. Would like to get this one assuming cheaper
'cup' 996 505 986 91 ??
Deeper lip and extends all the way around (worse for speed bumps!)
Thanks for that.I seem to remember reading about 2 types a while ago.
I rang my local OPC last week and he seemed to think there was only one and it was listed at £220?
Just be aware that the cup parts sits 20mm closer to the ground than a standard splitter and therefore you will be scraping it a lot more. I gave up using a cup splitter on the road.
Stuart - thanks for the detailed answer, I may have a very firm grasp on the wrong end of the stick but I still think I see two different non-Cup versions in the photos though?
Both of these are normal (non-Cup) depth but on one the lip protrudes all
the way to the end but on the other it blends back in the bumper? I think both are for 996.2 model
I'm not fussed which one I have but if there is a cheaper version out there which isn't as deep as the Cup it would be good to find!
The one with the pre-applied tape is standard and the extended edge version is cup (on red car), same as I currently have fitted. I'm pretty sure that's correct from memory. Every cup splitter I've purchased hasn't come with pre-applied tape and is definitely not as well finished as the standard.
If you read the rennlist link within the 6speed link it does mention that there is an aero version available but can't find part number, this may be the smaller of the 3 in pictures. Possibly the same size/shape as the MK1 GT3 splitter.
