Car pulls very well up to 3k revs, then seems to loose power.
seemed to be great when first purchased in October 2016. But did have one ht lead snapped going into dizzy cap, which caused bad idle and bad running below 2.5k revs. Run really well in the high rev range though.
Replaced the leads with brand new beru type, although seem a loose fit on the new plugs. Would this be a problem?
Replaced spark plugs with iridium denso type
Replaced dizzy cap with beru type.
Replaced rotor arm
Replaced air filter.
Lower rocker covers are original type and are leaking, I haven't done a compression test yet. Only been doing a coupe of hours work to the car on weekends. Will be replacing the covers with turbo style ones soon and checking the valve clearances.
Could rocker covers cause high end power loss?
Other things I'm thinking of soon: replacement coil and ignition module. Other people seem to be going for MSD Not sure to buy the MSD 6al 2 programmable.
Any feedback will be greatly appreciated.
