For the work I am doing on the instruments, I am reading the voltage from the coolant and oil temperature sensors, converting the voltage in mV using a third order polynomial to give me a temperature with a resolution of 0.1 degrees C, then using another 3rd order polynomial to convert from the required temperature to the required voltage to drive the display. This is then output using a 10 bit PWM output.
Inputs and output are working, so time to put in some equations.
I am converting the readings to a real temperature for output on RS232 and CAN, just in case I ever want to log them.
I am hoping that I can gain a tiny bit more if needed with the adjustable suspension arms. It should be on its wheels tomorrow so I'll see how the GT3 wheels tuck in.
The last of the replacement clips have been fitted.
With the driveshafts being fitted but not attached to the gearbox they need to be stopped from flapping around, so I taped a plastic bag around them and fitted them inside a cardboard tube and parts of a box to support them.
I did consider removing them but thought that not having the bearings supported properly would not be a good idea, this was confirmed by somebody I asked who knows a lot more than me.
The car is resting on its wheels for the first time in about 9 months.
Characterising the fuel gauge behaviour for data logging. This one is from a Boxster, so I will repeat for the C4, it gives me a baseline for my testing.
As expected there is a massive amount of damping on this.
It would be really useful if you have time to do something similar with the temperature gauge. A lot of people say you can't trust it, it's got a massive dead zone etc. But mine seems to be pretty good, it's always moving and seems to follow the climate control hack numbers well.
