asterix_the_gaul said:I think that Was The op's original plan.
Just which fuse to piggyback for his 996?
asterix_the_gaul said:Well, like I said you need a switched supply, so get a voltmeter out and check which fuses have a switched I.e. ignition on power, there may even be an unused fuse socket? then plug your piggyback positive in to that socket and find a screw to metal to give you your ground/negative. The little transformer box should tuck behind the carpet by the fusebox I would imagine, then run your cable: I would start at the camera in it's desired location then work back to power so you end up with any excess wire where you can hide it under the dash or carpet
