Brake pads
Cooper
18 Mar 2003
40
My pad wear lamp has recently came on (today). How long can I go before I have to change them (trying to drive sensibly). I realise there is no definitive time, but the reason I ask is that I am struggling to get the car to a a garage for a couple of weeks.
If it is important to change them (suspect rears at fault), is it a task which I could do myself, ie has anyone done it, was it hard. The car is a '92 C4 964.
Any comments appreciated.
Migration info. Legacy thread was 4599
Should be okay for about a 1000 miles if you don't go mad. Never tried doing the job myself.
Migration info. Legacy thread was 4615
Read on Rennlist that it SHOULD be reasonably easy to do. Will try, mainly because its a ***** getting anything done by a garage unless you foresee problems and book in before they happen!!
Cheers anyhoo
Migration info. Legacy thread was 4617
Isn't there an issue with needing a special tool to bleed the brakes on a 964 C4? Have a look on
www.porsche964.co.uk
. I am sure it will give advice there.
Cheers, James
Migration info. Legacy thread was 4623
Thats right. Hopefully though, I will not be nreaking into the fluid system so shouldnt need to do any bleeding anyway. I only just had my system bled through at an OPC when I had to get my booster pressure pump replaced.
Im going to do the job Friday, let you know how it went.
Migration info. Legacy thread was 4626
124,615
1,442,100
49,049
DarrellS
