jonnyspyder
- Joined
- 7 Sep 2020
- Messages
- 34
I have just removed and replaced my front bumper (2011 987 Spyder) and found a lot of corroded fasteners holding the bumper to the under tray or holding the wheel arch liners/brake air ducts in place, just wondering if anyone has found a better solution? The OE fasteners needing attention are the flanged black Torx head self tappers, two sizes: 4.8 x 16 with T25 head and 4.8 x 19 with T27 head (part numbers 999 073 22709 & 999 073 41801 resp). The shorter screws with the smaller Torx size heads are rather more feeble, they appear to be used where two panels are held together close to the bodywork but I think that the slightly longer screws will work without harming the body when in place... so has anyone found quality aftermarket screw of same dims, or has anyone swapped out with an alternate fastener that will work with the clips the tappers attach to - perhaps quick fit half turn Zeuss fasteners for example? I have scoured the usual aftermarket suppliers but either the flanges are too small or the correct size screw comes with the puny T25 head... any ideas/input appreciated
