Rosselder83
- Joined
- 1 Apr 2019
- Messages
- 264
After a bit of advice surrounding the oil scavenge system in the turbo.
After finally getting my car fired up (turbo replacement) I noticed the drivers side turbo was leaking oil from what I assumed to be the sump o-ring.
While I was double checking other stuff I had the outlet pipe off and I noticed there was a small pool of oil sitting at the edge of the compressor housings outlet pipe, not a bit deal if the car had been running for months but by this point it had run for about 3 minutes.
I emailed the chap that did my turbos and he was very happy for me to send it back down to him to check over, I'd assumed the large o-ring on the compressor housing had failed but he said it sounds like the scavenge system isn't working and that's forcing the oil out.
So I'm just looking for a way of testing his theory?
The oil pressure when the car was running was nice and high, the passenger side turbo has no leaks. They both have oil in the sump and in the lines.
What is the direction of flow? Is the oil sucked out of the bottom and returned to the tank? What's the upper line for? Is it just an over flow for the tank?
I can attach pictures if that would help anyone?
Thanks in advance
Thanks in advance
