A bit of a tricky one I've had a steering wheel upgrade from my original 997 turbo gen1 to 997 Gen 2 wheel.
The guys have got the wheel on and coded but it's slight off centre when I'm driving maybe about 20 degrees to the right. I'm not sure what to do either do an alignment where the alignment was perfect before or to reset the steering wheel maybe 1 spline not sure if the centre line was drawn but they had to take out the clock spring I guess to change the module
Any help/advice appreciated please as I'm. It sure what's the best option as not sure if an alignment would solve it as the spline probably has a certain number of turns and therefore it could cause problems with the wheel turning or maybe not ?
