SOLD
Sharkwerks muffler bypass for sale in excellent condition with less than 2000 miles on it for 991.1 GT3 or GT3 RS models.
£600 ono
contact me for further information or pictures.
From Sharkwerks website :
New $1500 + import duty , vat.
The new SharkWerks 991 GT3/RS Sport Exhaust dramatically improves the sound of any 991 GT3, Touring or GT3RS or 991.2 GT3. Much like previous GT3 models, the 991 version is just a tad too docile in stock form. This is in large part due to the strict sound-level restrictions in Europe and hence the factory deemed fit to equip these cars with a total of three mufflers again. With our Muffler Bypass System we believe we have addressed that and not only uncorked the beast that is the GT3 motor but also reduced a real 16 pounds off of the rear end in the process. This has been achieved without sacrificing the drivability or diminishing the aesthetics. Installation can be performed in around an hour without any rear bumper removal.
3-D CAD designed with optimal flow, fit, weight savings and sound enhancement, our system replaces the centre muffler on any 991 GT3. By utilising appropriately-sized diameter tubing and straightening out the flow we achieved our desired sound and minimised resonance. Our direct bolt-on exhaust installs into the factory location without any modification or compromise and is completely reversible.
Although we do not guarantee or make any crude horse power claims (let's face it Porsche did a wonderful job already on this one) we can assure you that you have not likely heard a GT3 sound like this before. By retaining and re-using the stock side mufflers and valves you are also able to continue to use the factory "sport button" valve feature to open/close and send the exhaust gases through the sides for a similar to stock sound when you want to cruise and be akin to stock or then bypass the sides for a more exotic sound.
As with all previous SharkWerks exhausts this system is 50-state emissions compliant but also does not cause any check engine lights (MIL Codes) as it is designed to continue to operate with the factory catalyst and emissions equipment.
Designed and crafted in Northern California, the SharkWerks exhaust utilises stainless- 18 gauge T304 tungsten inert gas welded stainless steel with mandrel bends and factory equivalent hardware.
Features
- Designed in-house and manufactured in Northern California
- Improved, more aggressive sporty sound (see videos below)
- Does not interfere with SMOG emissions and 50 state legal
- Factory headers, catalysts side mufflers and valves retained
- 3-D CAD designed factory fit direct bolt-on replacing factory side exhausts
- Direct bolt-on replacing factory centre muffler
- Compatible with either the stock or aftermarket tips
- Use your Sport button to divert routing to switch from flowing through the side mufflers to a direct bypassed flow
- Use the non-sport mode to allow flow through the side mufflers for minimal additional interior noise and highway or daily driving.
- Real 16 pound weight savings (stock muffler weighs 20 pounds total) from the rear of the car
Fraser
£600 ono
Features
Fraser
