I know there are plenty of threads on this subject already.
I have a 2002 996 which has factory Bose and original navigation, PCM with a telephone handset. (non-MOST)
I asked the garage to replace it with an Alpine ILX700. They did a bit of a hatchet job, wired the speaker out into the Bose and didn't connect any power to the aerial amp, so radio reception was pretty bad.
I ended up stripping it all out and working out how to wire in the preouts etc. Did all that and got it working ish. Problem is that it sounds awful. There is lots of interference type noises which is very noticeable. I've wired the HU into my stereo to eliminate that, it was nice and clean, no problems at all.
So it's likely to be incompatibility between the HU and the Bose system. Perhaps ground loops.
However I don't recall reading how people have solved the issue.
What did you guys do?
I'm not after concert hall, super-fi, the 996 is way too noisy for that, just something simple, nice and clean with BT music streaming and BT phone.
I may even go single DIN, like the Continental unit for 1990s looking simplicity.
- Live with it?
Put the original back in?
Ripped out the Bose?
