GT4
Nordschleife
- Joined
- 8 Nov 2008
- Messages
- 30,181
mankers said:^ Do you know the option code for LSD?
Option code depends on 2WD or AWD.
M220 = 2WD nonPSM = 40% (or dialable to 65% for track work)
M220 = 2WD with PSM = 22% (or dialable to 27% for track work)
X75 = AWD PSM standard = 22% (or dialable to 27% for track work)
Adjustment is via the diaphragm spring rates.
The PSM compliant low-locking 22%LSD was developed and offered after 2003 (MY2004/2005).
The low-lock LSD can be retrofit to any MY2004/2005 manual 996 (2WD or AWD).
There is no Tip compliant variant.
AWD LSD was not production line spec'able.
So if you had a MY2004/2005 C4, C4S or even Turbo,Turbo S you had to request an off-line factory bespoke mod.
The vehicle was built as normal then sent to the Special Wishes dept to be fit out with the PSM compliant 22/27% LSD.
As this was an "Exclusive" order it bears the code "X75".
Needless to say, this process added considerably to the order process (up to an additional 12 weeks).
It is debateable how much effect a 22% LSD (M220) model actually dynamically outclasses the standard Automatic Differential Lock (M224) on PSM equipped cars.
One big issue is the LSD is a wear and tear item and therefore without maintenance and replacement a worn M220 equipped car may fail to outperform an M224 car.
Then the LSD is just more weight at the back doing nothing!
