I have replaced the PCM2 and Bose with a Kenwood DMX8019DBAS using a Connect2 CTSPO004 adapter. All the functions work ok and I understand that it just uses L and R outputs to the BOSE amp.
Before I removed the PCM I set all the surround and fader/ balance options to zero.
Would it make any difference re-installing the PCM and setting the surround sound to 'on' and then refitting the kenwood?
