maldren said:demon said:EGTE said:Hartech recommend Millers Nanodrive CFS NT+ 10W-50 for higher-mileage cars.
It's what they use on the cars in their service/protection plan.
I put this in per their requirements re. running in the engine after their rebuild... and have used it ever since
- I either replace the oil once a year or every 10,000 miles
Tires, brakes and oil are the first places you should spend your money
'98 C2
230,0000 miles
Just noticed your mileage, any rebuilds in there?
EGTE said:I thought that this wear-on-start issue was obviated by a very high film-strength of the oil, so that you don't actually need it to be pumping around quickly while cold?
Reading this: http://eamvmotorsport.com/millers-oils-nanodrive-nt/ it says:
"These exclusive properties, protective film strength, of Nanodrive oil are very important as it ensures a high levels of protection during engine start up/warming up until engine reaches normal operational temperature. "
My car starts more easily and runs more smoothly on Millers 10W-50, that's for sure. :thumb:
Bluebird911 said:skinny_monkey's comment I agree with up to a point.
"For higher mileage engines it can be beneficial to increase viscosity but this applies more to the hot viscosity to maintain the minimum oil pressure and protect the bearings".
But disagree it applies more to hot engines. Cold startups cause the greatest engine wear and I believe a cold engine needs a higher viscosity oil at cold startup as well. The greater bearing gaps and other engine parts wear creates reduces oil pressure and without high pressure at startup, the oil will not get about the engine as designed potentially reducing oil circulation to some engine parts. A thicker viscosity oil will have a higher pressure increasing the speed of oil distribution. In addition for a daily driver, higher viscosity oils leave a better deposit of oil on the engine components overnight to reduce startup wear.
High viscosity oils are routinely used in old design engines that have inferior tolerances of modern design engines. In comparison, the 0W-20 Mobil 1 oil I use in my daily driver is like water!!
