***Non-Turbo 996 owners - Please read - IMS DATA REQUIRED***
date inputted: 15/01/2019
member: Wh1t3Kn1ght
model: 9961 C2
engine size: 3.4
purchase date: 13/10/2018
date registered: 15/12/2000
mileage (at purchase): 65029
mileage (now): 65391
bearing (orig./replacement): unknown
failure data (if applicable): n/a
comment:
IMS data - new owner
date inputted: 15/05/2019
member: James03C4S
model: 996 C4S 2003
engine size: 3.6
purchase date: 13/05/2019
date registered: late 2003 I believe
mileage (at purchase): 54400
mileage (now): 54700
bearing (orig./replacement): unknown but reliably informed that it's original as history of car has been traced back through George McMillan.
comment: The car required a new RMS when I bought it so had the clutch and IMS inspected at the time. The bearing was found to be in perfect condition.
date inputted: 14/02/2020 (updated).
member: DarthFaker
model: 996.1 Carrera 4, Manual.
engine: 3.4L M96.02
purchase date: 02/03/2019
date registered: 01/09/1999
mileage (at purchase): 74k
mileage (now): 82k
bearing (orig./replacement): Original Dual Row
failure data (if applicable): IMS worn @ 80k (Oct 2019)
comment: IMS bearing replaced.
Engine flush used and oil changed, replaced with roller type bearing. Filter checked after 2000 miles and clear of debris.
Date imputed 13/6/2019
Member brucey1
Model 996 .1 c2
Engine 3.4
Jan 2001
Mileage at purchase 79000
Mileage now 82000
Original bearing
New clutch fitted at 63000 by portiacraft , I take it the bearing was inspected at the time
Alex said:
Can you post your full details up then:
date inputted:12/07/2019
member: mattomg
model: 996 c4s
engine size: 3.6
purchase date: 04/2019
date registered: 04/2003
mileage (at purchase): 106000
mileage (now): 107000
bearing (orig./replacement):eek:rig (dealer said checked but no documentary evidence)
failure data (if applicable): none
comment:
tappets done in 2017. In process of slowly replaceing all consumables. Oil change 6 monthly, magnetic sump plug & nillers oil analysis due at next service
Re: ***Non-Turbo 996 owners - Please read - IMS DATA REQUIRE
Here's my data for my car.
date inputted: 16/09/19
member: Hughb
model: 996 Carrera 2 manual
engine size: 3.6
purchase date: 04/07/19
date registered: 01/07/03
mileage (at purchase): 85868
mileage (now): 86112
comment: clutch change at 48000, but no record on invoice of any inspection of ims bearing
Here's data my for my car.
date inputted: 18/10/19
member: AK996
model: 996 Carrera c4s tip
engine size: 3.6
purchase date: 11/10/19
date registered: 01/01/03
mileage (at purchase): 71000
mileage (now): 71200
comment: Original IMS , no mention of ims in paperwork/history.
Here's data for my car
Date Inputted: 30.10.19
Member: PhilipR
Model: 996 Tip, Cab
Engine Size: 3.2
Purchase Date: August 2019
Date Registered: 2001
Mileage [at purchase]: 54,300
Mileage [predent]: 55779
Bearing: Original
Comment: Original IMS
Please feed back when they tell you what it is. I'd be surprised if it was your IMS bearing.
Possibly so, the IMS bearing may be goosed, but it may not be the cause of the problem. Could have had a jammed valve or something that then put too much strain on the chains and bearing causing them to also fail.
Confirmed as IMS by specialist.
2yr update:
date inputted: 21/12/19
member: willy
model: 996.1 C2
engine size: 3.4
purchase date: 03/12/12
date registered: mid 1998
mileage (at purchase): 112000
mileage (now): 149000
bearing (orig./replacement): Original - dual row
comment: Clutch\flywheel replacement with IMS inspection @138000.
124,624
1,442,181
49,057
VeeRacer
