GT4
Nordschleife
- Joined
- 8 Nov 2008
- Messages
- 30,181
Having attended the Coupe Health Clinic on Saturday, I was given some homework to do.
Both rear disc's ventilation holes were partially occluded with pad residue etc, so having been offered either £150 OPC solution or some sly advice by the techy, I purchased a 4mm HSS metal drill bit and set about routing the holes DIY.
Equipment:
Safety goggles
Variable speed electric drill (low speed 500-600 rpm)
Wheel brace
Locking wheel bolt key (if applicable)
Wheel assist (locating peg) - in your tool kit.
Trolley jack
Wheel chocks
Box (to sit on)
Method:
Leave the handbrake off and out of gear and chock front wheels.
Loosen off bolts
Jack up just enough to remove tyre (ie 1cm etc of tyre clearance to ground)
Rotate so that one bolt is at the top
Remove top bolt and screw in wheel assist
Remove the other four bolts
Slide wheel off wheel assist (thus not damaging your wheel or brakes and not breaking you back in the process)
Drill each hole though to the rear of the disc.
There is a dust guard/protection shield just behind most of the disc, so I fitted my drill with a depth stop.
You can easily access about 1/3rd of the disc at a time (1/3rd is too near or inside the caliper, 1/3rd is too low for working on after Sunday lunch, leaving an easily assessible 1/3rd round the top/open side)
You can rotate the disc a 1/3rd at a time by using the wheel assist and pushing the outer edge of the disc round.
You should be able to tell which holes have been routed, but just in case, gently scribe a radius line so you know where you started and where you need to turn disc round to. Any surface scratch on the disc will get worn away almost immediately anyway.
Brush or hoover debris away.
Rotate disc so one bolt hole is at the top and screw in wheel assist.
Make sure the wheel/hub mating surfaces are clear.
Slide wheel back on and replace bolts in the other four locations
Remove wheel assist and replace with bolt.
NB: always remember to replace the locking wheel nut opposite the valve (otherwise you will loose concours points)
Tighten up hand tight, making sure the wheel/hub mating surfaces are square.
Drop the jack to allow tyre to make contact with the ground, fully tighten using the opposite in a circle routine:
1, 3, 5, 2, 4, 1 ... etc
When fully tightened to torque, drop fully and remove jack.
Repeat for other discs.
Job done - you may wish to add some bolt caps for cosmetic finish.
