I thought i would share some useful information, my low tone horn had been broken for a while and recently the high tone faulted. Ive got an MOT coming up so i took the front PU off and tested the voltage to both horns and both were getting 12v.
So i looked at getting a pair of replacement horns and OEM used pair were £40-50 on ebay.
I thought there has to be a common VAG part which is the same for a fraction of the price. I trawled through lots of vehicles looking for the small two pin connection that the 996 has. Eventually came across a BMW E46 horn which had the same connection. I bought a used pair on eBay £15 delivered. Admittedly the connections are facing a slightly different direction but the wire loom is long enough to connect OK.
Here's the BMW E46 part on carparts4less: https://www.carparts4less.co.uk/sea...L30rGGgXnjcObyRMLmqMtHrEO-N4tNtxoCq1UQAvD_BwE
I hope this helps other people out.
