Hi All
Our 2015 Macan has flashed up some lights/symbols. My wife was driving it a couple of days ago and several warnings flashed up at the same time - Suspension system fault Adapted driving permitted.
Fault parking brake - ABS/PSM failure Adapted driving permitted.
No all-wheel sys. Only rear-wh drives Adapted driving permitted.
Once the ignition was turned off and on again they all disappeared and all was good? I took it out to try and get it to happen again and it did but first I got the PSM warning light come on for a few seconds and I felt it cut the power a bit to the engine then the light went out (I also think I felt the abs on the brake pedal for a split second but not 100%) and a few seconds later I got all the messages my wife got.
Any ideas it does all reset once the ignition has been turned off and I have scanned for fault codes but none are saved ??????
Any else experienced this ??
TIA
TIA
