It's very rarely I find myself having to repair anything mechanical on my 993 but there always seems to be a list of things that need fixing on the electrics.
The latest one is I've noticed on the odd occasion I venture out after dark that other drivers keep flashing me with their beam even though my headlights are definitely dipped so last night when it was dark I parked the car opposite the wall and tried using the headlight level adjuster knob on the dashboard.
I've tried using this before whilst driving, but could never really tell if it was making any difference. Also, it is numbered 1 0 -1 and I assumed that 1 would be the highest and -1 the lowest. I got that completely wrong because on mine it seems that 1 is the lowest so I have now set it to 1.
But the problem I have is that only the nearside headlight is going up and down - although I have to say even that doesn't vary by very much, but it is definitely moving.
The offside one on the other hand doesn't move at all.
I turned the engine off and got somebody else to move the adjuster and I can definitely hear a motor turning in the nearside one when the adjuster knob is used, but the offside light is silent so the motor is definitely not doing anything.
I've tried cleaning the contacts in the plug on the back of the light unit with contact cleaner and also sprayed it into the socket that the headlight plugs into.
Is the motor the black 2 in.³ box that seems to be attached to the white plastic fitting inside the headlight unit? Looking inside the headlight I can't for the life of me see how the motor works or what it adjusts.
Just to add that the previous owner installed some kind of HID headlight conversion so each light unit is jampacked with a load of wires and transformer box type things (a large, thin silver box and a smaller rectangular black plastic box).
The dipped beam lights are very bright and I'm pleased with them, but obviously I could do without oncoming drivers blinding me with their beam because they are pissed off with the alignment of my lights.
I think the car has always been like this in the three years I've owned it, but I don't very often use it at night so it has not been a huge issue, but I really should get it sorted.
Interestingly, the car has passed three MOT's for me so I don't know what sort of alignment check they do at the MOT test centre, but it's obviously not very good one if my offside light is blinding everybody coming the other way.
So, a bit of a rambling thread to give you some background, but I'd like to know how to get the motor working if possible. And if that is going to be difficult can I just manually adjust the dipped beam in some way?
Cheers guys
Any help gratefully received
Cheers guys
