Headlight Help
AustinM64
29 Jun 2022
13
Dear All,
I went to change the High-beam bulbs as they were quite yellow compared to Dipped-beam and I discovered what appears to be an aftermarket Litronic kit.
When I put the light back in the Dip beam wasn't working. upon investigation, the black wire, which a previous owner had stuck in with tape, had come out. Despite super gluing it back in, the dip beam is still not working (I suspect I may have damaged the bulb in the process).
However, here is the problem. The connection to the bulb is not detachable. The wires from the bulb go straight to a connector! This means it requires a very specific bulb that has the connector attached.
Has anyone come across this setup before, does anyone have a work-around or do I need to source a new kit or something?
I have included some photos so you can see what I am talking about.
Any help gratefully received.
Austin
Photos.
It's a third party HID kit. That type of connector is pretty normal on those. You could probably buy another kit for about the cost of a new lamp.
Mine has an aftermarket HID kit.
I was worried it might fail an MOT, but apparently so long as you hjave headlight washers, they can pass. I suppose because this model could come with Litronic, if it has the headlight washers, most testers wont spot the aftermarket kit.
I have Litronics fitted after market so the washers and levelling don't work. I haven't had MoT issues.
124,621
1,442,166
49,052
Ravioli
