Appreciate some advice…
I have removed the 4 hoses (2 each side) from the front - 997.2. They were quite corroded but got them out cleanly from the plastic fittings to the radiators and one of the crossover fittings. It was a bigger struggle to remove from the aluminium crossover pipe on each side but I managed it and the remaining aluminium housing is in ok shape...signs of corrosion!!
I really want to avoid replacing the crossover pipes (I don't have the facilities to do it!) but want to be sure I get a tight seal when I fit the new hoses. Has anyone any suggestions for ensuring the seal is good?
I thought about adding some silicone sealant to the joint when I push in the new hoses...I know it's not ideal but interested to hear if there are any reasons why it wouldn't work or some better suggestions.
Thanks.
Thanks.
