plavix
Mugello
- Joined
- 16 Sep 2013
- Messages
- 2,208
I swapped out my exhaust last year, or was it the year before, and now have a used pair of Genuine Porsche (Eisenmann) PSE mufflers with PSE tips, including vaccum valves. All in full working order, although the right-side down pipe needs welding. Easy enough for any exhaust shop. They were on the car for around eight years / 50K miles. Valves were replaced under warranty in 2019.
I'm offering here before they go on fleabay, where they're rather expensive.
Right-side: £350
Left-side: £550
Tips: £200
I've priced in order to reflect the cost of repair, which realistically is going to be closer to between £50 and £100.
If you fancy, like me, going the whole PSE retrofit route, adding the electrics and vacuum lines is only around £200 in extra bits, plus fitting. I can sort out the part numbers required, and even get them for around 20% less than List. I'd recommend Zuffenhaus for fitting, as they're competitively priced, do a great job and they're genuinely a pleasure to deal with.
Right-side: £350
Left-side: £550
Tips: £200
