X911
- Joined
- 7 Oct 2021
- Messages
- 131
I changed my engine mounts for RSS mounts in the summer. Easy DIY I did on the drive but at the time I didn’t order replacement 18mm nuts for the long studs that go into the mounts. It bothered me so I ordered new nuts and went to fit them after work today.
First one the stud came straight out with old nut still attached. This happened when I took the old mounts out but I wasn’t so bothered then as I was throwing those out in any case.
The second one I’ve tried not to do that and try and remove the nut whilst stud is still attached to the mount but no matter what I do I cannot stop the stud from spinning with the nut staying firmly in place in the stud.
I’ve made sure that the square on the back side of the mount is sat in the square hole in the chassis but even still the stud just spins every single time.
Tried penetrating oil before I attempted this made no difference! Reluctant to use heat as some soft coolant pipes close by.
Anything I can do or just take the stud out, get it in the vice and whip the nut off and reinstall?
Thanks.
Thanks.
