Bit the bullet and bought the breather pipe, it's routed differently and the original interferes with the secondary throtte.
Fired her up sans cans what a racket. Couple of leaks from fuel filter and PS pipe so shut down quickly.
All cylinders firing and after building oil pressure without dme she fired first time. I'll complete the exhaust next and let her warm up properly. Not checked actuators yet but holding vac.
Lost the little retaining clip for the throttle pedal ball joint connector I reckon a paper clip can be modifide to fit.
Worst bit was fitting the air box, I had to drop the engine a bit which made it much easier. Lot less room in the engine bay now.
