Jason Taylor
- Joined
- 15 Feb 2012
- Messages
- 581
My rear dectane lights have developed an intermittent fault. I first got a check rear left indicator message, when I did this I realised the plug was slightly damaged and was working it's way loose, I've taped up the plug which has resolved the issue, however I'm now getting a check taillight from the same unit, wiring, plugs etc are all good, I recreated the fault by unplugging it to get the fault displayed but when I reconnected it the fault wouldn't clear. It's a bit of a lottery at this point as to wether turning the ignition on/off will clear the fault, sometimes it does, other times it won't. I'm guessing the issue is with one of the controllers attached to the rear of the light unit, is there an option to have these units changed or will I require a new unit?
Tia
Jason
Tia
Jason
