Space Cadet
- Joined
- 20 Jan 2022
- Messages
- 323
I don't use my car that much so if I haven't used it for a couple of weeks I connect the charger to it the night before
At present I have connected the short lead the charger comes with permanently to the battery terminals and left the plug in the battery compartment under the cover. My cover though is a bit of a faff to remove as one of the screws doesn't screw in or out properly so I have to spend a while slowly turning it while gently pulling up on the cover. Before too long the cover is going to break!
What I think would work is if I could route a longer charger cable (Ctek do a longer version) from the battery terminals into the frunk – is this possible please, are there any holes/grommets to let the cable through??
Or any other position suggestions??
Thanks!
Thanks!
