Carbon fibre mirror triangles 997 boxster cayman
Nattyboy
Nurburgring
4 Nov 2012
498
Brand new unused Euro cup GT carbon mirror triangles. For 997 and 987 boxster/Cayman gen2 models (2004-2012)
£85
Illustration of fitted parts (these are new and unused).
I ll take them please
Now sold
Thanks Nat, all fitted and looking good!
You're welcome mate !
You need to remove both mirror assemblies from car, Torx screws on inside behind inner triangle.
The mirror and casing need to be disassembled. Single screw on lower mirror body and be careful you dont break the moulded tabs on the plastic casings.
The mirror arm is fixed to the outer triangle with 3 small T8 Torx self tappers.
Remove the rubber gasket and you should be able to remove the mirror mechanics from the triangle by squeezing the arms gently.
Assembly is a reverse of the above. Fit the gasket after you have the mechanics through the triangle.
The small Torx self tappers were too small for the Carbon triangles, so either fill with epoxy or use a piece of cocktail stick inserted into hol;e in C/F part to give the retaining screws something to bite onto.
Nicely moulded and a massive weight saving :puh: :puh:
Doesn't sound too complicated apart from that last bit you mentioned. Does look cool, I am thinking of a splash of exterior CF on my motor.
1,442,218
49,059
newbieporsche
