Air con pump - best source for replacement
coullstar
Singapore
15 Sep 2015
2,834
Noticed a rattle from the engine last night and sourced it to a loose air con pump clutch assembly (the inner part is very loose).
With air con on its doesn't rattle but looks like new pump etc will be needed so where is best to source these from?
Don't need aircon for the moment so Ive switched off which Im assuming will be fine.
I bought a new pump, drier and O rings from autoairconparts.co.uk for £178.68.
Fitting the pump is not easy, I suspect you really need to drop the engine a bit to access the back bolt, I gave up and paid 9e to do it!
You may be able to just replace the clutch and that would be much easier.
Its not very hard to change the compressor, just a little fiddly. You don't need to drop the engine. You can't see that rear bolt but a socket with a wobble will get on it.
See my guide here:
http://911uk.com/viewtopic.php?t=93945&highlight=
You need to get the system vacuumed out first, its an offence to knowingly release these gasses into the atmosphere.
Will be worth changing the drier if the system has been open to atmosphere for any length of time.
Wish I'd seen your post before I tried it, mind I didn't have a wobble bar (I have now) and yes, getting the gas removed first is essential.
ELA has removed all of his aircon system and it was for sale. Worth a pm to him if you're happy to fit a used pump
Is the main part of the pulley that the belt runs on retained by a circlip and not the 10mm bolt?
Reason Im asking is that the centre part of the clutch is so loose, as all the rubber has melted, and it is very noisy rattling now and is making the whole pulley vibrate so if I can Id like to remove the loose part yet still drive the car.
Replacement pump and pulley is coming.
124,626
1,442,196
49,057
VeeRacer
