graham.hassall said:Thanks for this detailed post. Can you tell me how you attached the jig to the right hand side as all of the studs had sheared?
Graham
The jig is fixed in position by either screwing onto remaining 5mm or so of a sheared bolt or ideally two or by indexing into an un damaged tapping where a bolt came out OK or any combination of those two conditions. Download the stomski instructions for full clarification
