I've had the 996 C4S parked up for 18 months as home extension project took over. When I did park it up I disconnected the battery so when locking up for hibernation the comfort didn't perform, I never had an issue prior to this.
Roll on 18 months now the car is back on the road, the comfort opening i.e dropping of the window when opening from the inside and outside on the drivers side did work on an adhoc basis for a few days has now completely stopped working. Having searched the threads here, it appears could be a micoswitch? So not sure if I need a new door lock, just a microswitch? Any suggestions part numbers gratefully received.
Also the car double beeps when using the remote, not sure if this is related to the same issue, or whether it's something else I need to investigate.
On an aside note, it's great to be back in the 996, and is now the daily driver.
