infrasilver
Moderator
- Joined
- 4 Oct 2010
- Messages
- 9,934
It is common knowledge that a LWF does seem to wreck an M96 engine on the track. Did it get balanced paired with the crankshaft whilst the crankshaft was out of the engine?
NLW73 said:so how many m96 engines do you need to go through before you could have bought a proper engine and the mezger in the back of the GT3?
at 10-15k for a proper rebuild its not going to be too many.
infrasilver said:It is common knowledge that a LWF does seem to wreck an M96 engine on the track. Did it get balanced paired with the crankshaft whilst the crankshaft was out of the engine?
crash7 said:If the rebuild is done correctly you should not need to go through more than one. The M96 is raced in the Porsche club championship, on slicks, and as already pointed out by Hartech once rebuilt well there is no reason for it not to be reliable, particularly when used for fast road / occasional track day use.
There are many m96's that see trackday use without issue, when ever using an M96 on track is mentioned inevitably the suggestion that a GT3 is more suited comes up, it is, but is also 4 times the cost, and even the mighty mezger sees failures, albeit less but there are also less of them.
If 'more suited' to the application is the driver, buy a Caterham, for half the money it will muller a GT3. - Some guys want to track their 911 and are prepared to throw caution to the wind, although not a track car the C2 was pedaled around the ring by Walter during its development, even in standard trim its capable. - 95% of the cars on trackdays are not primarily designed for this purpose.
Each to their own, you pay your money you take your chances, you could write a GT3 off on the road, does that mean your not going to us it.
996ttalot said:infrasilver said:It is common knowledge that a LWF does seem to wreck an M96 engine on the track. Did it get balanced paired with the crankshaft whilst the crankshaft was out of the engine?
That actually needs a little more explanation. A factory crankshaft is balanced individually and then mated to flywheel whether LW or DM. As far as I am aware there is no balancing of the two together on the production line. The reliance is upon the manufacturing tolerances.
With DM fitted, the resonance it significantly reduced on the crank. With LW the resonance is increased. Lots of cars have LW fitted with zero issues where they had DM fitted. We have done loads without issues.
The problem we have found, is the quality of the manufacturing tolerances on a LWFW. You would assume, that manufacturers ensure that these are within a small spec, but that could not be further from the truth in our experience.
When we fit a LWFW, the flywheel and clutch assembly is checked and balanced. This is as much as you can do without having the crank in your hand.
We do crank/flywheel balance when building all engines. But imagine then that in a while you have to replace the LWFW for some reason - you are still in the same position.
Marky911 said:A GT3 is not 4 times the cost though.
I'll wager Ryan has £30k+ in his car. Anyone will have. It's £20k to have a sorted 996, unless you're very lucky with purchase such as Mister corn with his latest one, but that isn't a C2, although he may rip the front driveshafts out.
Say £13k for a decent C2, then coilovers and setup, fresh fuel and water pumps, rads etc. An engine rebuild to pretty standard spec is £12k+.
The ex 911 & PW mk1 GT3 sold last year for thirty something. It would be a no brainer. Even now you can get GT3s for £50k. The market peaked about 18 months ago. You'll see most of that back too. How much of your £35k will you see back trying to sell a tracked, modded C2?
Like you say, for some it simply must be a 911, but for me it would be a pointless expense and I'd be gutted to have over £30k in a non-mezger 996.
We all have our view though and I admire Ryan seeing his plan through, so I don't want to derail the thread.
Fair play Ryan, I bet you're looking forward to getting a load of track miles piled on. Enjoy the car. :thumb:
